Learn how to change the hostname on your Vultr Cloud Compute instance for proper system identification.
Changing the hostname on an instance modifies the default server configuration and reinstalls the operating system. This operation may results in data loss when the instance is reinstalled to apply the new hostname.
Follow this guide to change the hostname on a Vultr Cloud Compute instance using the Vultr Console, or Terraform.
Open your Terraform configuration for the existing Cloud Compute instance.
Update the hostname value in the instance resource.
resource "vultr_instance" "cc" {
# ...existing fields (region, plan, os_id, label, etc.)
hostname = "new-hostname"
Apply the configuration and observe the following output:
Apply complete! Resources: 0 added, 1 changed, 0 destroyed.
