Learn how to modify the startup script that runs when your Vultr Cloud Compute instance boots up.
Startup scripts allow you to automate specific configurations during the operating system installation. Changing the startup script on an instance wipes the file system and reinstalls the default operating system.
Follow this guide to change the startup script on a Vultr Cloud Compute instance using the Vultr Console, or Terraform.
Changing the startup script on an instance will wipe all data and reinstall the operating system.
