Learn how to monitor your Vultr Cloud Compute instances performance metrics including CPU usage, disk operations, and bandwidth statistics.
Monitoring an instance provides information about its performance and usage statistics. This enables you to track the instance's activity, health, and resource usage. You can monitor the vCPU usage, disk operations and bandwidth statistics on a Vultr Cloud Compute instance.
Follow this guide to monitor a Vultr Cloud Compute instance using the Vultr Console, API, or CLI.
Navigate to Products and click Compute.
Click your target Vultr Cloud Compute instance to open its management page.
View the instance usage summary within the Overview section.
Navigate to the Usage Graphs tab to monitor the instance's usage statistics.
Monitor the instance's bandwidth usage statistics within the Monthly Bandwidth section.
Monitor the instance's performance statistics within the Server Monitors section.
Click the Range drop-down to select a specific timeframe and view the monitoring information in the following categories:
Send a GET request to the List Instances endpoint and note your target instance's ID.
Send a POST request to the Instance Bandwidth endpoint to monitor the instance's bandwidth usage statistics.
$ curl "https://api.vultr.com/v2/instances/{instance-id}/bandwidth" \
List all available instances and note your target instance's ID.
$ vultr-cli instance list
Monitor the instance's bandwidth usage statistics.
$ vultr-cli instance bandwidth <instance-id>
