Learn how to restart your Vultr Cloud Compute instance through the Vultr Console or API.
Restarting an instance performs a hard reboot, stopping all running processes before starting them again. It does not affect the instance's data or file system and allows application updates or configuration changes that require a reboot to take effect.
Follow this guide to restart a Vultr Cloud Compute instance using the Vultr Console, API, or CLI.
