Learn how to temporarily halt your Vultr Cloud Compute instance while preserving its configuration and data.
Stopping an instance shuts it down and disables network connectivity until it is restarted. The operating system and all running processes are halted, but billing continues unless the instance is deleted.
Follow this guide to stop a Vultr Cloud Compute instance using the Vultr Console, API, or CLI.
Send a GET request to the List Instances endpoint and note your target instance's ID.
Send a POST request to the Halt Instances endpoint to stop the instance.
$ curl "https://api.vultr.com/v2/instances/halt" \
-X POST \
--data '{
"instance_ids" : [
"your-instance-id"
List all available instances and note your target instance's ID.
$ vultr-cli instance list
Stop the instance.
$ vultr-cli instance stop <your-instance-id>
