How to Change the Hostname on a Vultr Optimized Cloud Compute Instance
Updated on 24 November, 2025
Learn how to modify the hostname on your Vultr Optimized Cloud Compute instance.
Changing the hostname on an instance modifies the default server configuration and reinstalls the operating system. This operation may result into data loss when the instance is reinstalled to apply the new hostname.
Follow this guide to change the hostname on a Vultr Optimized Cloud Compute instance using the Vultr Console, or Terraform.
Warning
Changing the hostname reinstalls the operating system and wipes all the data on your server.
  • Vultr Console
  • Terraform
  2. Click your target Vultr Optimized Cloud Compute instance to open its management page.
  3. Navigate to the Settings tab.
  4. Find and click Change Hostname on the left navigation menu.
  5. Replace the existing value with your new hostname.
  6. Click Reinstall to change your instance hostname.
  7. Check the confirmation prompt and click Change Hostname to apply the new hostname.
  1. Open your Terraform configuration for the existing Optimized Cloud Compute instance.
  2. Update the hostname value in the instance resource.
    terraform
    resource "vultr_instance" "occ" {
        # ...existing fields (region, plan, os_id, label, etc.)
        hostname = "new-hostname"
    Apply complete! Resources: 1 added, 0 changed, 1 destroyed.
