How to Delete a Vultr Optimized Cloud Compute Instance
Updated on 10 September, 2025
Learn how to permanently remove a Vultr Optimized Cloud Compute instance from your account.
Deleting an instance permanently erases the server's file system and removes all IP information. This action is irreversible and any data on the instance data is lost unless a backup or snapshot is available in your Vultr account.
Follow this guide to delete a Vultr Optimized Cloud Compute instance using the Vultr Console, API, or CLI.
Warning
Deleting an instance is permanent and irreversible. Take a snapshot of the instance if want to recover the instance at a later time.
  • Vultr Console
  • Vultr API
  • Vultr CLI
  • Terraform
  2. Click your target Vultr Optimized Cloud Compute instance to open its management page.
  3. Click Destroy Server on the top-right navigation menu.
  4. Check the confirmation prompt and click Destroy Server to apply changes.
  1. Send a GET request to the List Instances endpoint and note your target instance's ID.
  2. Send a DELETE request to the Delete Instance endpoint to delete the instance.
    $ curl "https://api.vultr.com/v2/instances/{instance-id}" \
      -X DELETE \
  1. List all available instances and note your target instance's ID.
    $ vultr-cli instance list
  2. Delete the target instance.
    $ vultr-cli instance delete <instance_id>
  1. Open your Terraform configuration and locate the Optimized Cloud Compute instance resource.
  2. Remove the resource block or set its lifecycle to destroy.
    terraform
    resource "vultr_instance" "occ" {
        label    = "occ-instance-1"
        region   = "del"
        plan     = "vhp-2c-4gb"
        os_id    = 2284
        hostname = "occ-instance-1"
    # To delete, either remove this block from configuration
    # or run: terraform destroy -target vultr_instance.occ
    Apply complete! Resources: 0 added, 0 changed, 1 destroyed.
