How to Reinstall SSH Keys on a Vultr Optimized Cloud Compute Instance
Updated on 10 September, 2025
A guide for reinstalling SSH keys on your Vultr Optimized Cloud Compute instance to restore secure access.
SSH keys enable secure, password-free authentication for users accessing your instance over SSH. Reinstalling SSH keys resets the instance, wiping all data and reinstalls the operating system to apply the new SSH key details.
Follow this guide to reinstall SSH keys on a Vultr Optimized Cloud Compute instance using the Vultr Console, or Terraform.
Warning
Reinstalling SSH keys will wipe all data on the instance and reapply the selected SSH keys.
  • Vultr Console
  • Terraform
  2. Click your target Vultr Optimized Cloud Compute instance to open its management page.
  3. Navigate to the Settings tab.
  4. Find and click Reinstall SSH Keys on the left navigation menu.
  5. Select the target SSH key and click Reinstall.
  6. Check the confirmation prompt and click Reinstall SSH Keys to apply the changes, reinstall the instance and enable the SSH key.
  1. Open your Terraform configuration for the existing Optimized Cloud Compute instance.
  2. Update the ssh_key_ids in the instance resource to reference the new SSH key(s).
    terraform
    resource "vultr_ssh_key" "new_key" {
        name       = "mbp-ed25519"
        public_key = file("~/.ssh/id_ed25519.pub")
    resource "vultr_instance" "occ" {
        # ...existing fields (region, plan, os_id, label, etc.)
        ssh_key_ids = [vultr_ssh_key.new_key.id]
    Apply complete! Resources: 0 added, 1 changed, 0 destroyed.
