Learn how to reinstall your Vultr Optimized Cloud Compute instance to reset it to a fresh state.
Reinstalling an instance wipes the file system, resets all configurations, and reinstalls the operating system. Any data on the instance's file system is permanently deleted and cannot be recovered unless a backup or snapshot is available in your Vultr account.
Follow this guide to reinstall a Vultr Optimized Cloud Compute instance using the Vultr Console, API, CLI, or Terraform.
Send a GET request to the List Instances endpoint and note your target instance's ID.
Send a POST request to the Reinstall Instance endpoint to reinstall the target instance.
$ curl "https://api.vultr.com/v2/instances/{instance-id}/reinstall" \
-X POST \
List all available instances and note your target instance's ID.
$ vultr-cli instance list
Reinstall the target instance.
$ vultr-cli instance reinstall <instance_id>
Open your Terraform configuration for the existing Optimized Cloud Compute instance.
Trigger a reinstall by replacing the instance during apply.
$ terraform apply -replace=vultr_instance.occ
Apply the configuration and observe the following output:
Apply complete! Resources: 1 added, 0 changed, 1 destroyed.
