Learn how to safely stop a running Vultr Optimized Cloud Compute instance from the control panel.
Stopping an instance shuts it down and disables network connectivity until it is restarted. The operating system and all running processes are halted, but billing continues unless the instance is deleted.
Follow this guide to stop a Vultr Optimized Cloud Compute instance using the Vultr Console, API, or CLI.
