Learn how to reinstall or change the operating system on your Vultr Bare Metal server instance.
Changing the instance operating system wipes all data on your server and installs a new file system. This is important when changing your default operating system while maintaining your instance's IP networking information.
Follow this guide to change the operating system on a Vultr Cloud Compute instance using the Vultr Console, API, CLI, or Terraform.
Send a GET request to the List Bare Metal Instances endpoint and note the target instance's ID.
$ curl "https://api.vultr.com/v2/bare-metals" \
Send a GET request to the List OS endpoint to view all available operating systems and note the target OS ID.
$ curl "https://api.vultr.com/v2/os" \
Send a PATCH request to the Update Bare Metal endpoint with a new os_id value to change the instance's operating system.
$ curl "https://api.vultr.com/v2/bare-metals/{baremetal-id}" \
-X PATCH \
--data '{
"os_id" : "<new-instance-os-id>"
List all Bare Metal instances in your Vultr account and note the target instance's ID.
$ vultr-cli bare-metal list
List all available operating systems and note the target OS ID.
$ vultr-cli bare-metal os list <baremetal-id>
Change the target instance's operating system.
$ vultr-cli bare-metal os change <instance-id> --os <os_id>
Open your Terraform configuration for the existing Bare Metal instance.
Update the os_id value in the instance resource to the new operating system.
resource "vultr_bare_metal_server" "bm1" {
# ...existing fields (region, plan, label, hostname, etc.)
os_id = 2284 # New OS ID
Apply the configuration and observe the following output:
Apply complete! Resources: 1 added, 0 changed, 1 destroyed.
