Learn how to properly stop a Vultr Bare Metal instance to pause services while maintaining your configuration and data.
Stopping an instance shuts it down and disables connectivity to the main network interface. The operating system and all running processes are stopped, but the instance normal billing cycle continues unless destroyed.
Follow this guide to stop a Vultr Bare Metal instance using the Vultr Console, API, or CLI.
Send a GET request to the List Bare Metal Instances endpoint and note the target instance's ID in your output.
$ curl "https://api.vultr.com/v2/bare-metals" \
Send a POST request to the Halt Bare Metal endpoint to stop the instance.
$ curl "https://api.vultr.com/v2/bare-metals/{baremetal-id}/halt" \
-X POST \
List all Bare Metal instances in your Vultr account and note the target instance's ID.
$ vultr-cli bare-metal list
Stop the instance.
$ vultr-cli bare-metal stop <instance-id>
