How to Reinstall a Vultr Bare Metal Instance
Updated on 11 September, 2025
Learn how to reinstall the operating system on your Vultr Bare Metal instance while preserving your IP address and hostname.
Reinstalling a Vultr Bare Metal instance wipes the server file system, resets all configurations and reinstalls the operating system. Any data available on the instance's file system is permanently deleted and cannot be recovered unless backed up.
Follow this guide to reinstall a Vultr Bare Metal instance using the Vultr Console, API, CLI, or Terraform.
  • Vultr Console
  • Vultr API
  • Vultr CLI
  • Terraform
  2. Click your target Bare Metal instance to open its management page.
  3. Click Server Reinstall on the top-right navigation menu to reinstall the server's file system.
  4. Check the confirmation prompt and click Reinstall Server to apply changes.
  1. Send a GET request to the List Bare Metal Instances endpoint and note the target instance's ID.
    $ curl "https://api.vultr.com/v2/bare-metals" \
  2. Send a POST request to the Reinstall Bare Metal endpoint to reinstall the instance with a new hostname.
    $ curl "https://api.vultr.com/v2/bare-metals/{baremetal-id}/reinstall" \
      -X POST \
      --data '{
        "hostname" : "<new-baremetal-hostname>"
  1. List all Bare Metal instances available in your Vultr account and note the target instance's ID.
    $ vultr-cli bare-metal list
  2. Reinstall the instance with a new hostname.
    $ vultr-cli bare-metal reinstall --host <new_instance_hostname> <instance_id>
  1. Open your Terraform configuration for the existing Bare Metal instance.
  2. Trigger a reinstall by replacing the instance during apply.
    $ terraform apply -replace=vultr_bare_metal_server.bm1
    Apply complete! Resources: 1 added, 0 changed, 1 destroyed.
