Learn how to properly restart your Vultr Bare Metal instance when needed.
Restarting an instance performs a hard reboot and stops all running processes on your server before starting them again. Restarting does not alter the instance data or file system and enables the application of updates or configuration changes that require a reboot.
Follow this guide to restart a Vultr Bare Metal instance using the Vultr Console, API, or CLI.
Send a GET request to the List Bare Metal Instances endpoint and note the target instance's ID.
$ curl "https://api.vultr.com/v2/bare-metals" \
Send a POST request to the Reboot Bare Metal endpoint to restart the instance.
$ curl "https://api.vultr.com/v2/bare-metals/{baremetal-id}/reboot" \
-X POST \
List all Bare Metal instances available in your Vultr account and note the target instance's ID.
$ vultr-cli bare-metal list
Restart the instance.
$ vultr-cli bare-metal restart <instance_id>
