Learn how to modify the startup script that runs when your Vultr Bare Metal instance boots up
Startup scripts enable you to run specific configurations to automate the operating system installation processes. Changing the startup script on an active instance wipes the file system and reinstalls the operating system.
Follow this guide to change the startup script on a Vultr Bare Metal instance using the Vultr Console, or Terraform
name field and click the Type drop down to set the script type.Open your Terraform configuration for the existing Bare Metal instance.
Create or reference a vultr_startup_script resource and attach it to the instance.
# Create a new startup script
resource "vultr_startup_script" "init" {
name = "init-nginx"
type = "boot" # boot | pxeboot
script = <<-EOT
#!/bin/bash
apt-get update -y
apt-get install -y nginx
systemctl enable --now nginx
EOT
# Attach the startup script to the Bare Metal instance
resource "vultr_bare_metal_server" "bm1" {
# ...existing fields (region, plan, os_id, label, etc.)
script_id = vultr_startup_script.init.id
Apply the configuration and observe the following output:
Apply complete! Resources: 0 added, 1 changed, 0 destroyed.
