Permanently delete a Vultr Bare Metal server and its public IP. Keep a backup or snapshot, since this cannot be undone.
Destroying an instance removes the public IP address and deletes the server from your Vultr account. You cannot reverse this action, and you cannot recover the instance data. Back up all important files from the server before you destroy it.
Follow this guide to destroy a Vultr Bare Metal instance using the Vultr Console, API, CLI, or Terraform.
